door handle TSB
Old 06-23-2006, 12:07 AM
hazestang
hazestang's Avatar
Default door handle TSB
can't seem to find this, can anyone help I tried a search, but came up empty
hazestang is offline
Old 06-23-2006, 12:08 AM
pat6674u
pat6674u's Avatar
Default RE: door handle TSB
What'swrong with yer handle?
pat6674u is offline
Old 06-23-2006, 12:15 AM
hazestang
hazestang's Avatar
it doesn't close after you open the door, it sticks out I know I heard of other people having the problem and there being a TSB on it
Old 06-23-2006, 12:19 AM
beaustang
beaustang's Avatar
Why not just bring it in, most people have never even heard of a TSB.
beaustang is offline
Old 06-23-2006, 12:22 AM
windveilpete
windveilpete's Avatar
My car has had a similar problem. My window did not go back up after the door was closed. The dealershipjust had to reflash a switch or something, it was quick and easy.
windveilpete is offline
Old 06-23-2006, 12:24 AM
hazestang
hazestang's Avatar
ironically I was just thinking the same thing the service department at my "local" Ford dealer is worthless if you are paying them for something, they are all over it, but when it comes to getting service that is covered by warranty they suck I had to print out the TSB for the gas tank myself before they would replace it having the TSB in hand makes things go much smoother at this place and unfortunately they are the only dealer within a half hour
Old 06-23-2006, 12:33 AM
beaustang
beaustang's Avatar
Damn, that sucks! You would think a broken door handle would be pretty clearly a warranty issue. Good luck man!
ORIGINAL: hazestang
Old 06-23-2006, 12:38 AM
Justin_R
Justin_R's Avatar
I had the same problem with one of the door handles they adjusted it the first time and the second time they had to replace it, just go to your dealer and tell them about your problems and they should fix it if not than go to another dealer, Good luck.
Justin_R is offline
Old 06-23-2006, 04:19 AM
afixer
afixer's Avatar
ok so here are all the current tsb's as of 6/22/06 these arent links i just did a cut and paste. you all should know where they are i post them on another site and give them to the mods here when asked. but i dont see ont for the door.
Technical Service Bulletins
2005 MUSTANG - US (English)
06-12-11
LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
06-10-13
MIL P0463 OR ERRATIC FUEL GAUGE
06-10-10
AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-10-1
AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH
06-9-9
HESITATION ON ACCELERATION AFTER LONG CRUISE
06-7-10
MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V
06-5-4
PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING
06-4-9
A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS
06-4-7
TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
06-4-2
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
06-4-1
RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA
06-3-13
FUEL FILL SLOW, OR DIFFICULT TO FILL
06-2-9
DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V
05-24-6
CONVERTIBLE SYSTEM CONCERNS
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-20-2
REAR AXLE NOISE
05-19-10
LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-10
BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-16-12
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
05-15-13
FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-15-12
FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE 4/26/2005
05-15-2
GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19
INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-14
CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-11
FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-6
EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-7-3
AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
05-6-15
AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16
WELD BONDING PROCEDURE
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
________________
TSBs found:37
2006 MUSTANG - US (English)
06-12-11
06-10-13
06-10-10
06-10-5
5R55S - TRANSMISSION FLUID LEAK
06-10-1
06-9-11
LOUD TICKING NOISE - 3-VALVE ENGINES - STUCK LASH ADJUSTER
06-9-9
06-7-10
06-5-4
06-4-2
06-4-1
06-3-13
06-2-9
06-1-5
DTC P1000 MAY NOT CLEAR IN HIGH ALTITUDE CONDITIONS
05-24-6
05-22-8
05-20-2
REAR AXLE NOISE
05-18-7
05-16-12
05-9-3
________________
TSBs found:20
afixer is offline
Old 06-23-2006, 09:11 AM
Badash
Badash's Avatar
I have this same problem, however since I am in germany, the dealer here says if it isnt broken, then its not under warranty.
Badash is offline
Quick Reply: door handle TSB
