Can you get your car tuned for cheap....
Old 06-29-2006, 05:04 PM
LiquidLenny
LiquidLenny's Avatar
Default Can you get your car tuned for cheap....
without buying a tuner? Like at your local garage or something? Hey I'm a novice so forgive the stupid question. I just bought a CAI that's why I'm asking. Thanks.
LiquidLenny is offline
Old 06-29-2006, 05:08 PM
CMCs05pony
CMCs05pony's Avatar
Default RE: Can you get your car tuned for cheap....
Most of the tuners only work for one car at a time. So you couldn't start a business say, tuning people's mustangs for $25 a pop. Also, there is a code on the electronic module in the engine bay that is needed to make a tuner work for your car. so the chances of being able to get your mustang tuned cheaply without buying a tuner yourself are pretty limited... at least as I understand it
nobody who has a tuner has been unhappy with it. you'll hear time and again that they are "worth every penny"
CMCs05pony is offline
Old 06-29-2006, 05:12 PM
windveilpete
windveilpete's Avatar
I think what the question was... say if I lived 10 minutes down the road from babachips, do you think he would tune my car for me for cheaper than I could buy a tuner?
windveilpete is offline
Old 06-29-2006, 05:14 PM
CMCs05pony
CMCs05pony's Avatar
then Doug would have an XCAL2 that would only work for YOUR car. Pretty sure the answer is still no.
Old 06-29-2006, 05:15 PM
LiquidLenny
O.K. O.K. I understand now. I was wondering/pondering... if a car's computer would self adjust or sense that the air is say- denser and compensate accordingly to a newly installed CAI without needing to be reflashed? Does this ever happen? Like a plug n play on a P.C., is the analogy I'm trying to relay here.
Old 06-29-2006, 05:21 PM
CMCs05pony
CMCs05pony's Avatar
no the computer has its parameters (timing, AF mix, idle RPM etc...) programmed from the factory. these won't change unless you reflash the ECU with a tuner. so if your CAI is one that requires a tune, you'll have to buy a tuner. also, since these parameters are already locked in from Ford, using premium fuel will do you no good without a tuner... just another example
CAI/tuner... I don't have either, but nobody has corrected me yet, so I'm pretty sure I speak the truth.
Old 06-29-2006, 05:29 PM
BlueStang6
BlueStang6's Avatar
ORIGINAL: CMCs05pony
CMCs05pony is correct. Depending on the CAI you bought you may or may not need a tune. Assuming you have one that requires a tune, if a shop tunes your car they will probably not save your stock programming and if you ever had to re-tune to stock, say for warranty issues, well .....
BlueStang6 is offline
xbmx89
Texas Regional Chapter
11-10-2015 10:43 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
'stangdude
08-12-2015 01:27 PM
dragman72
08-09-2015 12:54 AM
Quick Reply: Can you get your car tuned for cheap....
