GT takeoff front sway bar
RE: GT takeoff front sway bar
It comes with a front; all mustangs have a front one, the std. V6 just doesn't have a rear, only the PP.
ORIGINAL: bluhawkshockey31
i know when you get a pony package it comes with the rear...but what about the front?
LX,
I don't think there is a problem with the GT takeoff install in your vert. I believe BEAUSTANG did install one in his, way back a spell. If you do it, don't forget the bushings, they are easy to install, the poly does make a difference, to me anyways.[sm=icon_cheers.gif]
I got them at Mustang Depot. The price was reasonable but the shipping cost sucked. It is a 35 mm bar ( the GT) this will remove any confusion in ordering. But I would suggest a little more research than I did to lower the shipping cost. They come with lube also, which is a nice touch. The oem bushing just slid off on mine, but if they are tight, a little silicone spray ill do ya!!
GOOD LUCK!! You won't regret It![sm=icon_cheers.gif]
I just put an '05 GT Coupe Rear Sway Bar on my 05 v-6 Vert this past weekend. It fits fine. You can order the hardware to mount it from a dealer for about $50. Also, see if they will give you the schematic where the hardware goes. It is a big help.
I also know the GT Takeoff on the front will work just fine too on your vert.
It makes a wonderful difference at least having a rear one on. You get very little body lean and it tightens up the feel of the back end. On the car.
