Exhaust installation questions
RE: Exhaust installation questions
Listen, I am the most mechanically inept person, but I am going to attempt to install a simple axle back flowmaster AT by myself. Wish me luck. I usually end up with minor bleeding and half in the bag by the time I get done with any mechanically related project. Thanks for all the help on these forums, Mustang owners are the best.
Just FYI take your time and remove the hangers, there is a hiden bolt directly above the Muffler, it should not take you more than an hour but make sure you jack the car up and secure it with stands so it will not fall.
why remove the hangers? you can slide them out with some lube and a screwdriver. It's really not a hard install, you could do it in 15 minutes. Jack up the car for sure though, i didn't and it took alot longer than it needed to.
does anyone have step by step easy installation for a single exaust upgrade or a duel exaust upgrade or what the easiest way to install it would be?
email me at trevell@rochester.rr.com
auto, axle, back, county, exhaust, installation, installaton, mustang, mustangs, ny, shop, westchester
