WHICH package should i get can yall help.
well I will be dropping another 1k into the stang my friday or monday.
SUSPENSION:
CHE-8KT includes the Fixed Length Tubular Lower and Upper Control Arms, Anti-Squat Brackets, & K-Member Brace with Torque Limiters. package is $471.99.
Tubular Panhard Bar Brace CHE-6N is $95.99
shipped i would guess would only be about 50 bucks more. Which leaves money left over for anything
Susension w/ PERFORMANCE: POWERHOUSE
direct bolt aluminum drive shafts for $499.99
Possible ford t-lock and bearing kit $299
shipped is guesstimate $1,475
PERFORMANCE only:
Ford t-lock and install kit $299
POWERHouse DRIVESHAFT $600 ( just guessing with shipping)
leavess alittle over for oil for rearend.
Autometer NEXUS WIDEBAND $399
or
PROCHARGER 12lb PSI pulley for $100
(re-tune) $200
GAUGE DISPLAY:
AUTOMETER NEXUS SERIES
WIDEBAND $399
FUEL PSI $190
Oil Psi $175
Water temp $180
CDC or MRT's dash pod 100
total roughly $1150
SUSPENSION:
PERFORMANCE only:
or
(re-tune) $200
GAUGE DISPLAY:
WIDEBAND $399
FUEL PSI $190
Oil Psi $175
Water temp $180
total roughly $1150
RE: WHICH package should i get can yall help.
suspension with perf sounds good.....
On the Nexus FP do a little research..... I know you just plug the network card into it...... but installing the sender is a real Biatch......
I am contemplating having to splice the lines with a "Y" block just to plug t he sender....apperantly, there isn't much room for a shreader valve arounf the rails....FYI
yeah i was talking to JUstin at VMP about it... ....
About the Gauge display.. I already have the dual tech only need the wideband .. but the nexus series is just badass looking i want the rest .LOL... so to actually finish it would jus tmean for me to purchase the wideband
ORIGINAL: armycook1981
ORIGINAL: Backlash
well then get the 400 $ wideband, ph driveshaft, and s/c pulley.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
