gears
gears
Got an automatic and Im looking to put in new gears but i dont know if i should take it to a 8.8 rearend 4:10 for being a daily driver also underpullys suggestions? also I was wondering the difference between h pipes and x pipes I want to put a dual exhaust in but i dont get the difference? But aside form all that I love my mustang I dont care for the stock wing but changing it to a xenon ducktail.
RE: gears
ORIGINAL: Mansmadlogic
I dyno'd a Y to an X and only saw a gain of 2HP, which is arguable on a dynojet to other conditions, so they all pretty much give the same gain. Sound wise my Y pipe dual setup and X pipe dual setup sounded the same (clips on my web site). H pipe sounds deeper in my opinion, but listen to some of the exahaust clips. NA, a single will give you just as much gain. Have you considered a single MRT or Flowmaster or other high quality less restrictive muffler?
RE: gears
goals well I would like to kick the snot out of a couple of cars i work with im more interested in street race then drag so maybe a 373 would be better but i have a cold air filter now looking to improve the exhaust want to change my underpully sway bar some shorty headers procharger that will be one of the last things depends on the stress its going to put on my engine some diablosport saw a couple of throttle bodys that i want to check out a little closer i wold like to be around 235 to 250 rwhp or better but we'll see
RE: gears
I would find out what your local shops support in terms of tuners. I had a Diablo and couln't find a local dyno shop that used them. I since then switched to SCT XCAL2.
With a really good tune, if you are a manual, you can hit 210-215RWHP which will put you at your goals.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
