3.73 FI streetabillity
RE: 3.73 FI streetabillity
ORIGINAL: flapjack
I've got the stock 3.31s....
ORIGINAL: armycook1981
rygen, werent you considering going back to stock 3.31 do to the rpm rANGE AND BOOST? JUST CURIOUS BECAUSE i got an lsd and woudnering if i should switch to 3.7's flaps running them your running them and justis running them in his vortech i believe. I was just told by procharger, powerhouse and a few other companies keep the stock ones .
opps i thought you had them .. then where you considering them... who else with fi here has gears
i floor mine so much the mpg went out the window along time ago.. i avg 13 mpg this past weekend while in houston with the other stangers.. i Used 1 whole tank in one day..WOW that was fun lol
Depends on how much highway driving you do, and what speed you travel. 3.73's are nice, but my 2006 is my 9th Mustang. I have added 3.73's multiple times, and it's worth jumping to the 4.10's. I run 3000rpm at 80mph or 75mph at 2800rpm on the highway. If you don't run too much on the highway, I would go to 4.10's and it will help if you decide to change wheel/tire sizes. Most 20" rims have a 28" diameter, which lowers the overall ratio. As long as you do your upfront homework, I'm sure you will be happy.
Hope this helps!
Hope this helps!
