New member, body kit question
Hey guys, sorry if some of the questions I am about to ask have already been answered
I have a month old V6 and am going to be doing some body work to it, a body kit to start with, the most expensive then move to upgrading the engine. I found the Boy Racer kit, but instead of the big wing on the back I'm going to put a duck tail spoiler, it looks pretty good. My question is it says that a GT Grille is required to install the Boy Racer kit, but I have seen pictures of it installed without the front GT Grille and fog lights, does anyone here have any insight into this?...I like the grille and light kit, can find a V-6 one on mrbodykit.com, but it is not the diamond pattern, it is a straight line pattern but made for the V-6 if anyone is interested...I would like to go ahead and be able to install the body kit witout buying the grille and lights just yet, want that to be a bit later, but if possible I was thinking about not going with that at all and just going with a dif grille than tha plastic stock one....But if anyone has any knowledge as to if I can make it work without and how to do it I would be greatly appreciative
As a side note, don't know if you guys know about this website, but it is called ponybuilder.com, a really great site to select your mustang and do body modifications and such and be able to see what it looks like before purchasing....They have quite a few body kits to choose from as well as being able to choose your model, color, wheels, spoilers, can even lower it to get a look at it
Hope this helps
Hope this helps
RE: New member, body kit question
the V6 and GT grills are different. The reason you need the GT grill is because the cutout in the front bumper is sized to fit a GT grill. You can find the replacement GT grills just about anywhere and put one of those on. They do make them without foglights.
ORIGINAL: workshop4ever
It sounds like you don't already have a GT grille so be sure you get the direct replacement grille, not the overlay type.
ORIGINAL: Adian
How much trouble will it be to install a GT grille that doesn't have the fog lights?...Will there be much modification needed to make the grille and kit mesh together correctly?
Everywhere I have been reading it talks about the problems in converting the GT grill to fit the V-6, talks about shaving things down and snipping parts off and what not, but since i am replacing the entire front bumpre with the Boy Racer bumper, will I have any of the problems I have been reading about in other posts?
ORIGINAL: Adian
carid
08-25-2015 08:17 AM
Soldier GT
08-12-2015 03:46 PM
