Hey Thanks Guys
RE: Hey Thanks Guys
ORIGINAL: mister ed
True, I figure at 158 bucks and some change, most bang for buck. Since I'm down 2 cylinders with less torque, that 4:10 should launch me like a V8. I don't believe that would void any warranties? The only thing that I am not to sure of is how its going to handle when I'm driving that puppy in the winter in NE ohio.
ORIGINAL: rygenstormlocke
That will get you out of the hole right quick, I would throw a LSD in at the same time since labor will be the same.
I can see the laughter from a mile away, but what is a 4:10
RE: Hey Thanks Guys
ORIGINAL: mister ed
gear ratio of axle...
Higher numbers indicate 'lower' gears, which allows your car to accelerate more quickly. Lower numbers indicate 'higher' gears, which has a greater effect on top speed.
Think about a 10 speed bike - start out in 1st gear and you can pedal like hell right away, but you don't cover a lot of ground with every pedal revolution. Try to start out in 10th gear and you almost can't get moving - but you will go a long way with every turn.
Which ratio is "best" for your car? It depends completely on what you are trying to accomplish.....
QWKYNUF
RE: Hey Thanks Guys
ORIGINAL: orion6g
I'm guessing that the speedo has to be recalibrated for different gear ratios?
Just kidding, sorry....
Yes - but that's whey you get a tuner, right?
QWKYNUF
RE: Hey Thanks Guys
Any kinda idea how much it would be out going from 3.31's to 3.73's? I have a tuner coming but it will be shipped to the place that I am going for vacation in ~2weeks, and I have a 1500km+ drive to get there.
RE: Hey Thanks Guys
RE: Hey Thanks Guys
If I have it figured correctly, Speedo should read fast by about 12.5%.
The 3.73s are about 12.5% lower than 3.31s, and your driveshaft would have to rotate faster for any given wheel speed than before.
So 67.5 on the speedo would give you 60 actual road speed, and the faster you go, the farther off you would be.
QWKYNUF
QWKYNUF
Soldier GT
12
08-20-2015 09:42 AM
Soldier GT
08-12-2015 03:46 PM
