Is Pirelli Nero Zero tread directional - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 2005-2014 Mustangs > V6 S197 General Discussion
Reload this Page >
Old 08-28-2006, 02:52 PM
LX200
Default Is Pirelli Nero Zero tread directional
I should be getting my GT takeoffs soon.. and was wondering... from looking at pictures of the Nero Zero tread, it is not symettrical. So, I assume they have to go on one side? if so, how do you tell which side. In the center zone of the tire, there are three curved cuts in the tire. Two sweep one way, and one sweeps the other.
Do they go one so the point of the two sweeps is in the forward rotating position?
See picture here
http://www.pzeronero.com/en_PZ/produ...0003&s2=600002
LX200 is offline
Old 08-28-2006, 03:59 PM
MikeHawke
Retired MF Moderator
Default RE: Is Pirelli Nero Zero tread directional
one side of the tire is clearly marked "outside".
MikeHawke is offline
Old 08-28-2006, 06:26 PM
GrayPony
Quote:
On the outside, the P Zero Nero M+S radial's silica-enhanced tread compound is blended to provide adhesive characteristics during high temperatures in the dry and low temperatures in the wet or snow. This compound is molded into an asymmetric tread design that features stable outside shoulder blocks combined with notched, continuous center ribs that increase footprint rigidity to enhance grip during acceleration and braking. Shoulder grooves and circumferential channels allow water to flow through the tread design to resist hydroplaning and enhance wet traction. On the inside, the P Zero Nero M+S features twin steel belts to provide strength and durability on top of a polyester cord body.
GrayPony is offline
Old 08-28-2006, 06:48 PM
LX200
ORIGINAL: MikeHawke
That really doesn't help. That makes sure the tire is mounted on the wheel correctly. Now, I can mount the wheel on either the left or right, in which case the pattern rotating forward toward the road is different.... they're not symettrical, so there has to be a "right" side to put them on.
LX200 is offline
Old 08-28-2006, 07:06 PM
joshetc
Uh, it does help. You mount the outside of the tire on the outside of the wheel. Then you put them on your car facing "outside" If you put them on the driver side outside will be on the left and on the passenger side outside will be on the right (from the driver's seat)
joshetc is offline
Old 08-28-2006, 10:05 PM
MikeHawke
ORIGINAL: LX200
ORIGINAL: MikeHawke
That really doesn't help. That makes sure the tire is mounted on the wheel correctly. Now, I can mount the wheel on either the left or right, in which case the pattern rotating forward toward the road is different.... they're not symetrical, so there has to be a "right" side to put them on.
Sorry I bothered to go outside and actually look at my tires so I could try to help you.
Anyway, I just went out and looked again and that's all it says on them. "outer". No direction. Just "outer".
The tread is in opposite directions on each side of the car too but the side of the tire marked "outer" is always "out" so, I think that's all that seems to matter.
Old 08-28-2006, 10:06 PM
nicarc369
^ had a better answer.
nicarc369 is offline
Old 08-29-2006, 01:41 AM
LX200
Wow... asymettrical tread and it doesn't matter which way they are mounted? That is really weird.
LX200 is offline
Old 08-29-2006, 01:44 AM
LX200
ORIGINAL: joshetc
This is weird. It means dispite the fact that the treads are not symmetrial, it does not matter how they are put on...... hummm....
LX200 is offline
Old 08-29-2006, 08:48 AM
jim01028
ORIGINAL: MikeHawke
ORIGINAL: LX200
ORIGINAL: MikeHawke
You are right, of course the outer will remain on the outside no matter where the tire is mounted on the car. This is not a tough problem guys!
jim01028 is offline
jwog666
01-07-2018 07:16 AM
kartracing87
09-28-2015 11:01 PM
mungodrums
The New S550 2015-2020 Mustang
09-28-2015 10:54 PM
popsotto
09-28-2015 06:58 AM
Featured Sponsors
