ungoverned top-speed??????
RE: ungoverned top-speed??????
>120, ran out of speedometer at 120, so I'm not sure. Been going to try it with the GPS tracking my speed, but haven't got it done yet. Kind of backed off the speed runs once I found out about the driveshaft problem at speeds above 115. I need to install drive shaft loops and/or an improved driveshaft before trying it again.
ORIGINAL: Meph
Haven't, but with factory setup I don't see it going much faster. 115-120 maybe. Beyond that probably depends if you're going downhill with a breaze behind ya.
I've had mine up to pegging the speedo, 120mph. I do have the pony pack, and had the driveshaft balanced by local driveline shop. Had to get the tires rebalanced at dealer, and a four wheel alignment, then at my last speed run, the little v6 auto pulled hard all the way to 100, and still had some left at 120mph, but I didn't. Thats right I lost my nerve, thinking of all the things that could go wrong, like tire blowout, driveshaft/u-joint break, engine suck a valve, spin a bearing , or worst a cop catch me ! Go to jail, get the stang towed, stupid tow driver mucking up my stang, going thru my stuff, and then the legal crap. Here in MO, 120 mph is felony speeding. Automatic go to jail. So unless you all have a lawyer on retention, take my word that your little v6 pony will go much faster than the speedo. Thats why ford put the speed limiter setting in the pcu, to keep a bunch of rookie drivers from destruction !
I bumped my speedlimiter settings in the SCT2 tuner to 120. Figured that was fast enough, anything that can catch me on the road, will probably outrun me anyway, so no use in breaking my ride.
If left stock diff gearing, for the auto its 3.31 gears and final overdrive, I would not be supprised to see the little pony hit 140mph.
That kinda sucks...I like top safely take her up to speed but i dnt have a pony package so i'd have to upgrade the driveshaft after i get the tuner but oh well even 120 is pry fast enough for now.
