GT Front Bumper..AGAIN!!
RE: GT Front Bumper..AGAIN!!
I did mine without the lower radiator shield...haven't had any problems...
The fender liners are in the wheelwell...you only need to replace the front half...go to FordParts.com and do a search...
And for those who did install the lower radiator shield, what parts did you get to attach it??
ORIGINAL: ilduce321
so you only used the fender liners? what about the isolator? that piece of styrofoam? did u use that too?
Here is the list of everything I used with no issues whatsoever...
1. Front driver side wheelwell liner - front portion
2. Front passenger side wheelwell liner - front portion
3. GT front bumper cover with GT grill and GT fogs
You don't need to replace the isolator, the one you already have is sufficient...
You don't need the lower radiator shield...if you feel you're going to be driving over 90mph for prolonged periods, then look into one, otherwise I've been driving without one for about 3 weeks or so now, going up to speeds (in short bursts) of 100mph without any issues. Just relax buddy. Follow the "How To" in the appearance section, and about 2 hours or so after you start, you'll have your GT front end installed.
