So, about that popping noise.....
I read about a popping noise that was accuring from
the front of some of the S197 stangs something about
a TSB and I had the same thing happening so I went to
ford today, but I have 36,400 miles on the Stang, and I
don't have extended warranty. My question is, is this
something that requires you to have a warranty, or is it
something Ford is required to fix on all Mustangs with the
same problem?
Thanks for the help guys!
same problem?
RE: So, about that popping noise.....
If it is not specifically labeled a "recall", then it is not a required fix. TSB's are primarily to help service techs with some commonly re-occuring problems.
There are a couple of TSB's that I think should be recall material, but so far, for '05 and up, I am unaware of any actual recalls.
Please correct me anyone if I am a bit off on this explanation. [8D]
ORIGINAL: celenztah
Only other way of getting it for free would be if it's a recall, and you would definitely know if it was, because those are a big deal. Plus Ford would probably send you a letter saying so.
