How to spin both tires.
#21
RE: How to spin both tires.
Just a quick question, why not spend a little more and swap the rearend for the GT's 8.8" it's an easy replacement in fact I did a quick search on car-parts.com and came up with several 8.8s either in the 3.21 or 3.55 for well under $1,000
#22
ORIGINAL: smythge
all you need for a break in is 3 heat cycles
also even wiht 4.10s you will still get 20+ mpg
if you do alot of hard launches and are a 5 speed, i would look at the true trac instead of the tlok
#23
If you like to drive 80 MPH on the highway then get 3.73's. I have 4.10's and I rev about 3000 on the highway at 80 and it sucks. I'm actually going to upgrade to 28" tires from top to bottom to take off about 200 RPM's which will make it only a little higher than having 3.73's. Everything will fit in the stock housing but they'll probably have to get some new shims and so on and so forth. They will also have to callibrate your speedometer.
#24
ORIGINAL: AmericanMade
Dan04COBRA
09-30-2015 11:46 AM
mungodrums
09-29-2015 09:18 PM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
