Car running like sh!t
Car running like ****
A month or so ago I had a Gt takeoff installed in place of the factory muffler. I then had the car tuned. Everything was fine.
A week and a half ago I received the drivers side GT Muffler(part of the diversified marketing deal) and decided to run duals all the way back.
Since then my car has been idling funny. It has even stalled at red lights on a few occasions. Even when I am sitting still it doesnt even go up tp 1000 on the RPM guage
Anyone had this happen or do you think it is something all together seperate?
Any help is appreciated
RE: Car running like ****
When I went to duals back when I was NA, my first dual kit was the Magnaflow kit. Instructions said to disconnect the battery and then reconnect it to force the computer to adjust for the increased air flow. Been awhile, don't remember the exact details. But I would give that a try, just disconnect it for 5 minutes then reconnect it.
I have dual GT take offs, nothing wrong with idle... and your car is not supposed to idle at 1000 rpms at a stop light... more like 600 or 800.. only upon start up is when it idles higher.. The ECU in our stangs sometimes needs to be reset every once in awhile.. so do what Rygen said and disconnect the battery... then put it back and see what happens.. it might seem like the car is slower but its just the ECU re-learning itself.. hehe..
[IMG]local://upfiles/40863/26E46143505440879AA429BEF79C008B.jpg[/IMG]
If I disconnect the battery will that have any affect on my tune? Also I was looking over my Diversified invoice and noticed they sent me a muffler from an Automatic, not a stickshift. Does that matter? I already had a GT bolt on from a stickshift. Not sure if that means anything but apparently I have one muffler from a stick and one from an automatic installed
ORIGINAL: ScreaminYellow
Also.. someone said you can turn the key to auxiliary.. wait for the dials to stabilize, depress the gas pedal and release it slowly, turn the key to off.. then start the car. They recommended that for throttle lag.. so I'm thinking it might "reset" the computer too.
I tried what you guys said and it seems to still be doing it somewhat. It isnt like it is undrivable but even if you go back behind the cars you can tell the air coming out doesnt sound right
I called a local SCT dealer about it(was gonna make an appointment for next week) but they said I need to get in ASAP because this could do some valve damage
Not sure if this is true or they are just trying to get me in faster
I went over to SCT's website and they have an open forum where they ask questions. Here is SCT's response
Ryan@SCT
Admin / SCT Employee
That should not have an effect on the way the vehicle runs.
Do you still have the stock O2 sensors in the stock locations?
Ryan
Ryan@SCT
Ryan
