New Exhaust sounds terrible!
Old 11-21-2006, 09:53 PM
petepete
petepete's Avatar
Default RE: New Exhaust sounds terrible!
H pipe
X pipe
I really suck at explaining things but the hpipe gives it a bit more throaty sound.These are great for chambered mufflers such as the gt take offs or flowmasters. X pipe gives a little higher pitch but more hp gains.This sounds good with magnaflows or slp loudmouths because they are already a little higher pitch and are basically just straight pipe. Straight pipes also sound a bit higher pitched and without f/i i can see how it could cause some loss of hp on the low end but gain on the high end. Im not sure if that is true or not. I used to have the gt take offs with an hpipe and it was really deep and loud. Now i have maganaflows and will be doing straight piping as well no sure how it will sound but i have a feeling it should sound pretty good. Here is a ssound clip from hambone with the magna flow offroad x pipe and gt duals. http://marklhammond.googlepages.com/exhaustvideoclips As you can hear its prety low but can be a little bit more high pitch at the high end. With h pipe i always sounded pretty deep. Also hpipe gives you some of that gargling sound which some people like( i do) but some people dont. Hopefully someone can jump in and explain the difference in pipes better for you
petepete is offline
Old 11-21-2006, 09:57 PM
ScreaminYellow
ScreaminYellow's Avatar
Would I not get the same effect by adding a cross pipe to my current configuration?
ScreaminYellow is offline
Old 11-21-2006, 09:58 PM
ScreaminYellow
Also which is the cheaper way to fix the problem. A new H pipe or just replace the Mufflers?
Old 11-21-2006, 10:01 PM
petepete
petepete's Avatar
really i cant really tell you. Each setup is going to sound very different. It really depends on how you like the sound. If you want it deep. your gonna need an h pipe
Edit: An hpipe will probably be cheaper than getting straight through mufflers like magnaflows or slps.
petepete is offline
Old 11-21-2006, 10:08 PM
Horrific_Ending
Horrific_Ending's Avatar
just slap a Prochamber on there if you dont want to go with a H-pipe. apparently mac's prochamber gives you more "horsepower". well that what will from mac told me on the phone. but yeah i say go with a H-pipe. Plus never let someone at a shop tell you want to put on your car. Remember its you car and your paying them to do what you ask not tell you what to do to your car.
Horrific_Ending is offline
Old 11-21-2006, 10:58 PM
boomerman
boomerman's Avatar
Wouldn't the simple answer be just to take it back and tell them how you wanted it done?
Sounds like he did it how he wanted not the way you wanted it done.
boomerman is offline
Old 11-21-2006, 11:01 PM
Horrific_Ending
yeah basically just go back and tell him you want it done the way you told him to do it.
Old 11-21-2006, 11:08 PM
ScreaminYellow
In all fairness to the shop in my case, I just told them to run the true duals, nothing about an H pipe because honestly, I didnt know..
I just need to figure out how to fix it.
Guess I will get the H pipe
Old 11-21-2006, 11:45 PM
Andaloro99
Andaloro99's Avatar
I am going back tomorow and I'm going to have him put the H pipe on like he was supposed to do the first time. I didn't have time to deal with it today and he WILL do it for free. One of the reasons for this post was also to find out if the H pipe would help the sound. Thanks guys, it sounds as if it will.
Andaloro99 is offline
Old 11-22-2006, 12:46 AM
AmericanMade
AmericanMade's Avatar
Get an H-pipe. A lot of GT guys are also prefering H-pipes over the X-pipe because it sounds better at higher RPM's. The H-pipe is there to balance and equal out the exhaust. I had no H-pipe before also and when I got the H-pipe installed... it was A LOT deeper and throatier! You could also add a could air intake and tune to make it sound even BETTER! Hope I helped a bit.
AmericanMade is offline
Quick Reply: New Exhaust sounds terrible!
