3.73 gears
3.73 gears
What else would I need to put 3.73 gears on my car?
I only have the ring andpinion .
Oh yea ill be getting a t lock too. soon.
gear oil? what kind? I kinda need to know asap. thanks guys.
RE: 3.73 gears
ORIGINAL: chavalo_nm1
Edit = link...
Not necessarily this brand name, but you will need a shim kit, if you have alot of miles on your diff now, you should replace the bearings as well...................anyway look around.............Ford Racing I am sure has a kit as well. fordracingparts.com
Cheers!!
RE: 3.73 gears
you need a motive bering kit
id also get a girdle especially with a tlok, if your a 5 speed esp, i would run a detroit true trac
scroll down
http://www.3.8mustang.com/forum/showthread.php?t=183112
that was a 4500 rpm cutch drop with DRs on 212 rw/ft/lbs on a tlok WITH a girdle
scroll down
RE: 3.73 gears
Since I'm looking to do this soon as well, is a bearing kit absolutely necessary, or is it just something that would be nice to include?
ORIGINAL: mustangman02232
scroll down
scroll down
RE: 3.73 gears
For all you Mustang owners who have never worked on a rear-end before but want to swap their gears please, please, please resist the urge! Pay a professional to do it right. I've seen a car loose a wheel and axle because the c-clip wasn't installed correctly, LSDs chew themselves apart because they wern't shimmed properly, and even whole rearends come apart because they were driven dry.
While this isn't rocket science and there are plenty of pictorials on the net there's also alot of detail involved that's often lacking. You need to know what gets lock-tighted vs. antiseized, which seals have to be replaced, how to tell a good girdle from a POS and so on. The cost of installation is small compared to what you can loose from an improper installation.
mark h
mark h
RE: 3.73 gears
ORIGINAL: ilduce321
scroll down
scroll down
its like running a premium tune but using 87 octane w/boosteron it[8D]
