JBA Evol Dual Cat Back H system install
RE: JBA Evol Dual Cat Back H system install
It can be done without a lift, but getting the old pipe off is a pain - you have to lift the right rear of the car pretty high. JBA does recommend that you have the joints tack welded, as they do tend to slip with use. The most important part is making sure that you have the h-pipes on the correct sides. Lay them both flat on the ground with the crossover pipes touchingand make sure that the back ends point upward. It's worth it to take the car to a muffler shop after the install to have the pipes aligned and tack welded.
