T-Lok & Gears
RE: T-Lok & Gears
ORIGINAL: v6VenoM
so ur saying 4.10's are better? and should i do the T-Lok and gears together or it dont matter?
If this is a second car or you do not plan on taking long trips and more of a local get around car that you will race more than average go with the 4.10's
If this is your only daily driver that you actually go on long drives or trips and not so much into racing the car all the time then I would go with the 3.73's
I would do the T-lok and gears at the same time to save on labor.
Eric
RE: T-Lok & Gears
yea sumone else told me to do it at the same time. and its def my daily driver. but are u saying that only because of the gas mileage or because of some other factor? because if its only me losing gas **** it..i used to fill up $500 a month now i do less than half that so it wont be a big issue for me.
RE: T-Lok & Gears
I think the shift patterns for the 4.10s make daily driving more difficult for stopping/acclerating, but I'm not sure.
ORIGINAL: v6VenoM
RE: T-Lok & Gears
ORIGINAL: v6VenoM
RE: T-Lok & Gears
ORIGINAL: Black06stang
ORIGINAL: v6VenoM
RE: T-Lok & Gears
ORIGINAL: fazm
actually our 1st gear is incredibley short, its around 3.7 or 3.9 thats VERY short
4.6 GEAR RATIOS
1st 3.38:1
2nd 2.00:
3rd 1.32:
4th 1.00:
5th 0.68:
Reverse 3.38:1
Final drive 3.55:
Optional 5-speed auto (5R55S)
1st 3.22:1
2nd 2.29:
3rd 1.54:
4th 1.00:
5th 0.71:
Reverse 3.07:
Final drive 3.31:
4.0 GEAR RATIOS
1st 3.35:1
2nd 1.99:1
3rd 1.33:1
4th 1.00:1
5th 0.68:1
Reverse 3.15:1
Final Drivw 3.31:1
Optional 5-spped auto (5R55S)
1st 3.22:1
2nd 2.29:1
3rd 1.54:!
4th 1.00:1
5th 0.71:1
Reverse 3.07:1
Fianl Drive 3.31:1
RE: T-Lok & Gears
4.10s are perfectly fine for a DD, my buddy lost 2 mpg on the highway and stayed the same in the city
i will recomend you get a limited slip unit put in along with the gears,i will NOT reccomend thefactory FFRP tlok especially wiht a 5 speed
RE: T-Lok & Gears
to answer your question 83rd, my plans are to a vortech in. I'm currently saving up for it. Like I said I'm very new to all of this so I just take the advice you guys give me and go with it.
