Hesitation from stop light
Hi everyone,
My wife's '05 V6 auto had the fuel pump replaced because of a TSB (hesitation after long drive and stopping at stop sign and hesitating on take off) Now it hesitates (since the fuel pump was replaced)almost all the time from a stop until it is completely warmed up. It also will do it after a good drive and then stop at a traffic light for awhile and then accelerate. This seems to only happen in first gear. Any thoughts on this would be deeply appreciated.
RE: Hesitation from stop light
There is a torque limiter with all of the 05 + mustang v6s. IT prevents us from really launching in first gear (in an auto). In order to get rid of this you have to get a tuner and then you will be good to go. I got an SCT xcal II and some tunes from a non sponsor of this site (just search for Doug on here and it will help, if you wanna know where I got it from pm me). MADE A HUGE DIFFERENCE! I put an 87 performance tune, 93 performance tune, and a 93 torque tune on it. I can peel out in first now. The torque on the 93 performance is amazing and the shift points are so much stronger. It really is like driving a different car now. It feels so much closer to the 99-04 gts! Awesome.
That's what you need to get to make a Big Difference.
Thanks 05mig6r,
But, this is not from a launch. This is about half way thru first gear it falls on it's face and then picks up again.I would like to get this fixed before I add any mods/tuner. Thanks for your reply!
I really don't think modifying it with a tuner and intake is a solution. The bottom line is, the car shouldn't hang at all.
It would seem it's gone from bad to worse after the TSB. Back to the dealer with ya.. [X(]
Thanks SPARTAN V6,
I agree, but if they can't duplicate this hesitation they won't fix it because ford won't pay for guess work. Has this situation happened to anyone? That is the hesitation after starting out from a stop sign?
Haven't tried that, but it happens before it shifts into second. I would say about 3000 rpm, maybe a little higher. Can't say it ever did it on kickdown or cruising at highway speeds. Just when I pull out in traffic and step on it a little. Very nerve racking.
ORIGINAL: Dreamer
Thanks scrming for trying to help,
When this happens it is about 1/2 - 2/3'sthrottle and does it in first at about 3000-3500 rpm from a stop.It's like running out of gas and then getting gas again so it doesn't kill. I haven't noticed this happening at any other gear just when starting out. I did take it into the dealer this morning. I hope they find something and will post the results if and when it gets fixed. Nobody else had this happen to them?
