pzero tire pressure
Old 02-14-2007, 09:48 PM
MrSandman
MrSandman's Avatar
Default pzero tire pressure
is the psi on the stock pzero's 51 psi? I just ran over an f'n screw and my back passenger side tire is hissing. The screw in the flat part of the tire.. in between the treads.. so i am going to plug it. Since it's about 18 degrees outside.. should I fill it up to 51, put it on the car.. then make it equal to the rest of the tires...?
Stupid question.. I know..
Btw.. i looked on the side.. and I think it says 51.. but i've put so my tire shine on the damn things I can barely read it.
MrSandman is offline
Old 02-14-2007, 09:57 PM
kidrobotzero
kidrobotzero's Avatar
Default RE: pzero tire pressure
i think its 31
kidrobotzero is offline
Old 02-14-2007, 10:10 PM
MrSandman
MrSandman's Avatar
damn... I thought 51 seemed high... but it sure looks like 51.
Old 02-14-2007, 10:15 PM
MrSandman
MrSandman's Avatar
looks like it's 51
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
Old 02-14-2007, 10:18 PM
Mountain Mustang
Mountain Mustang's Avatar
Look on the edge of the drivers door. It will give the correct pressure for the car .
MM
Mountain Mustang is offline
Old 02-14-2007, 10:47 PM
MrSandman
MrSandman's Avatar
Ah.. that would have been a lot easier.. thanks.
Old 02-14-2007, 11:18 PM
rls82959
rls82959's Avatar
I believe 51 is the max. That would be hard as a rock. I run 34lbs in mine.
rls82959 is offline
Old 02-14-2007, 11:41 PM
JochenHeiden
JochenHeiden's Avatar
My door jam says 31, but I run mine around 34.
JochenHeiden is offline
JochenHeiden
Also remember there's a significant difference between hot and cold tire pressures! ;-)
Old 02-15-2007, 01:08 AM
MrSandman
MrSandman's Avatar
My other tires are at about 35psi. I filled it to 40 and will check them all in the morning. Wasn't too hard of a fix..just used a kit and filled it up with my compressor.. decided to wash it while I was at it which is fun when it's 14 degrees... even in my garage.
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
marc954
09-29-2015 11:18 AM
Quick Reply: pzero tire pressure
