Pony Emblem Placement
does anyone have the pony package with side pony emblems? i'm about to purchase a pair and want to place them as close as i can to where ford places them. thanks all.
RE: Pony Emblem Placement
Picked this up from some other forum.
" Here are the measurements in case you don't want to just eyeball it:
3 1/2" from fender edge at door to pony's tail
4 3/4" from fender crease above pony to top of tri-bar
As for getting those plastic tabs off, I just used pliers to break them and then filed the rest down. I also scratched off the included adhesive so I could use 3M double-sided tape, but that was probably unnecessary. Be sure to clean the fenders before you apply: dishwashing liquid + water solution is good to get rid of wax and grease, followed by a final wipe with isopropyl alcohol. "
Hope it helps .
Hope it helps .
