PVC Valve
PVC Valve
ok i just posted below but i have a question i had to cut the breather hose that goes to the PVc Valve and the connect a rubber hose supplied by the maker of the CAI i just installed and the fitment between the plastic stock one and the rubber one is kinda loose couls that be the reason that my car starts up for like 2 seconds then shuts off
RE: PVC Valve
yes, its causing a large vacuum leak that thepcm can't compensate for and stalling. you need to make sure that all vacuum lines are tight. i remember the k&n i bought i had to do some modifying for my pcv tube.
RE: PVC Valve
eh screw it here it is when i took apart the intake system i had already had a cold air filter on it when i connected the new high flow tube i out the MAFS collar on backwards so the senor wasnt getting any air and stalling out the car
