Car shakes at idle
RE: Car shakes at idle
It does seem to be worse when the ac is on. But since I have the CAI, will that be a problem when I take it in? If all you guys say its not normal I am definitely taking it in. When my advisor came back, I knew he was blowing smoke up my ***. Oh well, I will just try a different dealership.
thanks for everyones help.
Take the cai off .....Assume the tuner does not have a tune so you are stock......right?
Take it off and put the airbox back on, verify the car has the same behavior completely stock..... if it doesn't...well you know!
If it does (still shakes stock) take it to "another" Dealer since the one you took it to is worthless...... It should not shake!!!
Just curious what CAI are you running without tune?....that might just be your issue
I do have a tune now, I know I will have to set that back to stock. However, I do not have to stock airbox, I can't find it. Will this be a problem? F***in warranties...
btw this was happening before the cai and tune.
And I do need to update my signature
ORIGINAL: 05mig6r
and demmand they fix it!!!
Ask around..... many of us still do have the stock box.....check around your locale..... What stateare you from? if you are in MD you can borrow mine...
Other than what has already been mentioned, you could have an injector or injectors not giving a good spray pattern. Bring to the dealer and have them run an "injector clean" through the motor. It's a process that they shut off the fuel pump and run the motor just on this "Injector Clean" until the can runs out. Costs $89 but it works like a champ. Of course this is assuming the rest of your motor is dialed in. Tune etc. I did it every 20k to 25k on my other cars and always worked. Your almost 29k so it could be possible.
Mine shook a bit and I noticed that when the turn signals were on it would shake each time the signal would engage. It was a simple idle adjustment and all is back to normal.
