my trunk lid decal finally came in
RE: my trunk lid decal finally came in
If its the vinyle then just get a spray bottle and fill it with soap and water. Then spray the sticky side and position the vinyle on car. It will dry and stick. The air bubbles will go away in about a week.
go to the hardware store and get some napha . its a cleaner detailers use to remove wax build up. clean it a few times the wet the area with the soap water solutiuon then wet the decal as you peal it . place it where you want it and squegee out the water from the center. after a few days you can rewax the area. good luck . 3m also has some install tips
If your talking the stripe inbetween the taillights good luck. I did it and it was a "F" pain. Cut the hole around bezel close as you can. Soap the **** out of it, work from center out with sqeege. Air bubbles don't come out after unless serious sun. Even then you'll need to use a pin and press out the water bubble. The hardest is around the bezel. (fake fill door)
so when you wet the back of the decal and the trunk is that so the decal will not stick right away so you can position it ?????? if so how long after can you drive it and what kind a soap and what % of mixture with water should it be????? thanx guys so far you shed alot of light ....
Lots of good info right here;
http://www.baltimorestreetmods.com/install.htm
However, your original post said it was a sticker. These are directions for a decal...Need to determine which it actually is...If it's an actual peel and stick sticker, these directions won't apply. Stickers are tough, and unforgiving......
Mike
Mike
jwog666
12-27-2021 08:09 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
movielover40
09-15-2015 10:37 AM
