has anyone done the gt takeoff brake conversion?
RE: has anyone done the gt takeoff brake conversion?
that should be it.
when i had my v6 i threw oem GT rotors on it without any issues... not sure about you 05+ guys though.
i know i needed calipers/rotors/pads/and brackets when i did my Cobra set up though...
the only thing your missing is the brackets and i am not sure if you need them or not to be honest.
Hey Eric,
Did mine last week, I am sure yours has the brackets............it's a direct swap, put the GT brackets on your calipers and swap rotor.........nothing else needed..unless your original pads are worn, I would use the new pads.....
Cheers!!!
Cheers!!!
the only things that are dif are the front rotors (larger) and the mounting brackets. they offset the caliper for the larger rotor. the front and rear calipers are the same as the gt.
So, where can I get the mounting brackets? I have the GT front calipers as part of a package deal, but if I do not need them I wont use them. I am pretty sure They did not come with the mounting brackets.
ORIGINAL: merlinsrealm
I am not for sure but, anybody doing take off brakes, Roush, Saleen they have their own brackets for their brake sets...........the Ford bracket would definintly be a take off part.........so it would come with the take off brakes..............I in the beginning bought the brackets from Ford, but returned them......I went through the bracket thing....................post a photo and I can tell if the bracket is there..........
Cheers!!!
Happy Bunny Day!
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
