weird sound at startup....help!
Old 04-20-2007, 02:07 PM
SeanoStang
SeanoStang's Avatar
Default weird sound at startup....help!
i have a 2006 v6 with dual magnaflows
the car makes a funny noise at idle, like at stopsigns and such. it vibrates the car a little and maybe its exhaust drone, but its only at idle. most often happens shortly after starting up the car, so not like in the middle of a drive. could it be just the motor warming itself? cuz my mom's lincoln does the same thing?
SeanoStang is offline
Old 04-20-2007, 02:53 PM
SeanoStang
SeanoStang's Avatar
Default RE: weird sound at startup....help!
nobody?
Old 04-20-2007, 03:41 PM
deanack
deanack's Avatar
I have the same thing. I have headers too. Something must be rubbing. It stops at 1000 rpm. Can the slow idle be set faster? I can't find anything either.
Dean
deanack is offline
Old 04-20-2007, 10:41 PM
Puleo76
Puleo76's Avatar
that happened to me also... re-adjust the pipes.. the driver side pipe is more than likely rubbing against the spare tire well... loosen the bolts... stick a piece of cardboard between the tight spot and then while the cardboard is still there tighten everything up and take out the cardboard... if u did it right, u should be fine.
Puleo76 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: weird sound at startup....help!
