LS Differential
RE: LS Differential
ORIGINAL: rjb
ORIGINAL: MrSandman
Also... if you have a 2007 Pony Package, it would be very rare that you don't have TCS.
These cars come with an open differential from the factory. If you have an LSD.. it was added after teh car was delivered to the dealer, or someone else put it on.
If that's the case.. your lucky!
I had a loaner that had the TCS (evident by button on the dash to turn it off). Mine doesn't have it. And yes I can leave 2wheel burnouts at will. Any way I am happy .. My build sheet doesn't mention the gear ratio, TCS or LS. I am going to climb under and look at the tag. BTW I bought it with 6 miles on it.
ORIGINAL: rjb
I understand LS, When I dump the clutch both tires are grabbing. Two black marks 10' long. I guess that answered my question.. I do have a LS and just thought it was standard and people were swapping because the other brands of t locks are better. BTW I don't have the traction control system..
RE: LS Differential
if it leaves 2 marks you either are just getting luck or the previous owner did something, ford used the 7.5 rear in the 6ers to save money and weight, the 7.5 tlok was designed for a 120 HP bronco2/ranger and ford didnt want to deal with warrenty issues (yes flame, yell, bitch, **** and moan all everyone wants) you will need to either buy a ffrp tlok from ford, orsomething like a detroit true trac
your rear dif would say something like 3 31 75
GTs should say something like 3 31 88 LS
gear ratio, diff size, and LS being limited slip
jack up the rear end of the car and put the car in neutral, and spin a tire, if the other tire spins in the same direction its limited slip, if it spins the opposite direction it is open diff
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
KingRando
10-02-2015 08:06 AM
09-16-2015 07:53 PM
