Nino duals are on ! finally
RE: Nino duals are on ! finally
ORIGINAL: jcoggin
so you had to tap the drivers side to make threads for the hanger bolts?
Yes . The holes are already in the left side frame the same as the right frame but they are untapped . Just use a bolt from the right side muffler hanger to tap the hole .It will make the threads .
ORIGINAL: tientran
Loosing backpressure and the car looses power ? It may be right in theory, but in reality it is not right. I have true dual with X pipe from Ford Racing. The car runs stronger and no more throttle lag.
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
