GT Swaybars
RE: GT Swaybars
Got mine from them also but the u clamp / brackets that hold the ends on were not included, likely I got srewed, but it's too late now to do anything about it
ORIGINAL: 4Rowdy
ORIGINAL: jim01028
The rear brackets are $20 each .
What brackets? When I got my GT Takeoffs (2-3 weeks ago)they came with all the bars, U clamps, bushings, links... The ONLY thing I had to purchase was the nuts and bolts for the rear, and reused the front bolts. Maybe it depends where we are getting our stuff, different supplier = different parts inluded? (mine came from NewTakeOff.com aka Diversified Marketing)
ORIGINAL: jim01028
RE: GT Swaybars
ORIGINAL: Denny Carlton
Ok People!
What will the sway bars do for my ride?
Short and simply!
Thanks,
Denny
Ok People!
Short and simply!
Thanks,
Denny
Had I not got involved on theis forum, I would never thought about the rear bar. But I kept reading how everyone seemed to be doing this, and it was a mod that was affordable, so I tried it. Very glad I did!
RE: GT Swaybars
ORIGINAL: 4Rowdy
Well, I am not a tech expert, but I found out from adding my sways, the car stays level at all times. When you go around a corner the car does not lean, it stays level. I had a gallon jug of water in the trunk, as a tester actually. On the way that morning to go have the bars put on, the gallon jug fell over and was rolling around the trunk. After the bars were put on, the same gallon jug of water stayed where I put it, upright and did not fall over, let alone roll around back there. My hubby followed me in his truck both times, to the shop and home, and said you could see the car tilt to the side when you round a corner, but on the way home with the bars on, it did not tilt.
Ok People!
Short and simply!
Thanks,
Denny
Ok People!
Short and simply!
Thanks,
Denny
RE: GT Swaybars
Do you think 200.00 for everything on the GT rear sway bar is a good price?
Thanks for the compliment on the dog, she is a malamute & samoyed mix, 9 years old, 100 lbs, & very spoilt!!! The other one is a huge puppy, pyrenees & malamute, 18 months old, 110 lbs, thinks she belongs in your lap!
RE: GT Swaybars
hey rowdy....i remember you said that i needed to buy 4 of all the nuts except for one of them...well they allowed me to order the exact quantities that i wanted and no error message came up. Do you think that i will later on get effed and not get the right amount?
09-01-2015 08:16 PM
mdvaldosta
08-23-2010 06:08 PM
2004MustangGT
11-28-2005 11:21 PM
