Rear end shot
Rear end shot
15000 miles and the rear went! i waas driving down doing 35 all i heard was a lound bang and then somegrinding the car drove fine all the way to the dealership so now im out of a car for a couple days what luck,
RE: Rear end shot
Is your car being fixed under warranty? Did the dealer notice that you had a CAI and tunes on the car or did you put it back to stock? Just wondering in case I have a problem and need to take my car to the dealer.
RE: Rear end shot
ORIGINAL: zid3
wasnt your rear end then...
RE: Rear end shot
Hit some road kill? .... I hit a dead dog some years back with a Iroc Camaro. It was dark and i didnt see it. All of a sudden BOOM... I pulled off to the side of the road and when i went to put the car in park the shifter was jammed. Turns out when i hit the dog it jammed my shifter into first at the tranny but i didnt know it at the time. I ended up driving home in first at 15 mph bah.
RE: Rear end shot
ORIGINAL: zid3
RE: Rear end shot
it was the rear end when he opened it up the gear fell out he said it has been like that for sometime and was surprise it last that long, funny part is that the way the gear loged it self made it like a makeshift posi but its coverd under warenty they said nothing about all the work hell he even fixed my rear saleen sway bar(bracket bolts snaped) as long as you go to a good dealership your in the clear, he acully is putting in the 3.55 gear he found for 7.5 i didnt even know they had the 3.55 for the 7.5, but anyways i always go to the same dealership and the same guy, i was thinking about doing the t-lock and gears since the rear is open anyway, but moneys shorts(even tho labor would pretty much be free) what luck right
RE: Rear end shot
ok, im going to either call bs, or the guy u were talkin to had no idea what he is talkin about.
for one, if the gear was broken (ring, or pinion) the car would NOT have driven at all, nevermind fine all the way to the dealer. secondly, NOBODY makes a 3.55 gear for the ford 7.5 rear end, does not exist. a 3.31, 3.45, 3.73 are the closest you can get ot the 3.55 gear.
