The N/A way!
The N/A way!
I was thinking about doing a vortech charger early next year, but my dad might not allow it. It is my car but he helps with insurance, insurance is under his name, gave me $12k towards the car, and I sill live with my parents and commute to college. He said if I do anything to my car w/o his ok, I am going to have to look for another place to live($2k+ a month) and then won't be able to afford any more mods. So he said he'll think about it but its a strong no now. And since he said he's got no problems w/naturally aspirated mods, I'll look into that. I was already thinking JBA duals, w/an h-pipe, and JBA shorty headers. Maybe heads and/or cam w/dyno tune(want to see someone get a dyno 1st though w/that set-up), Andthe only other cheap HP bolt-on I could think of is the alternator UDP. Has anyone had good or bad experience w/UDP and these cars? Also, state what brand u have too. Thanx for the help!
RE: The N/A way!
I'd go with a CAI+Tune, MAC Long Tube Headers, Dual Exhust with H Pipe (doesnt really matter what exhaust you go with), Underdrive Pulley System.
you could also ask for a supercharger with very low boost.
RE: The N/A way!
First, it's not my dad's car. He's driven it twice since I got it in the spring. BTW we both have the same name except I'm Jr and insurance is only under him so I save a $1k+ a yr. I tried the 3yr warranty thing but vortech only keeps it if u stay with the 5/6psi pulley which would only net me around 40-50rwhp for $4k+. And it's cheaper N/A for me to go that way, maybe even with just heads, UDP, and a dyno I could get those gains. I wanted to do LT headers but I can't sincemy state has emissions. So I have to stick with my plan ofshorty's and dual h pipesystem. UDP will be a yes after I get some opinions. And recently I've looked into Western Motorsports ramair system for $350 thatshows dyno gains over 20rwhp on just their 80mm mafsystem w/no tune. I was wondering if the 95mm maf system would fit our cars, it doesn't say and with the numbers of the 80mm maf, I'd expect 35-50crank hp from this system at least if I get heads. It's like a mini-blower. Anyone purchased this yet? And if so, doI need to get the tuner too or is their a tunealready on my sct for it's95mm maf?
Thanx for the help!
Thanx for the help!
RE: The N/A way!
ORIGINAL: SteelStang05
Thanx for the help!
Thanx for the help!
RE: The N/A way!
Thanx for the help(read my sig already have gears and tuner), what about the 80mm maf ram air system? I am still in college so cash is limited(I should have $3k to spendby February or as I go along). So right now I'm doingshorties and duals w/h-pipe($900-$1.1k installed), UDP ($anyone no installed), and possibly heads(if I have the money)or ram air($500-$600 installed)which shows 20+rwhpgains on the dyno. But the reason for ram air not showing huge dyno gains like it should is because the car isn't moving. Like WMS said, they saw 20+rwhp gains on the dynobut the in a test run 50-100mphw/2 identical cars(except for ram air), the ram air did it in 1.5sec's quicker! That's what a car with 70+ more hp(crank) would do it in! So, w/o counting dyno #'s, theoretically u gain 2-3+X's the dyno's #'s. For weight reduction I was thinking BMR front sway/radiator support kit($180) that takes off about 40lbs and am not sure about anymore lightweight stuff i could buy. Does anyone sell cams for our car that don't need new heads? I'd look into that cause heads r expensive and with my budget I might only be able to afford the cam w/everything else. Thanx for all the help!
Joe
Joe
RE: The N/A way!
Thanx for the help!
Thanx for the help!
