Dual Exhaust Question
#21
RE: Dual Exhaust Question
ORIGINAL: SteelStang05
u can either buy a dual/cat-back system for the V6's on v6mustangstuff.com, but their really expensive and the true duals w/o a mid pipe sound sheety. U could do like I did and just buy separate parts u need and have the mechanic/exhaust guy weld it together and install it. To do this u need to buy a mid-pipe(gt-takeoff h's r cheap), get used overaxel pipes from a gt or buy them from Ford, and buy a set of 2 mufflers(GT axelback). That's what u need to do that. I did that and saved enough money on the mid pipe and overaxels that I got shorty headers too. Installed, this whole project will run me under $1k. Pretty Good! Hope this helps!
1K?? You weren't foolish enough to pay thatfor what you have listed were you?
My JBA kit with an H cost $400 and the install at Midas was $80
#22
ORIGINAL: angera
Can you buy the parts seperately? Like the one girl got the GT stock mufflers and I dunno what else she did? Or do you have to buy a kit like on the link you showed? Is there an advantage to X vs H?
What would the average price be to buy all the junk and install it? Does it void your warranty if it isn't done by the dealer?
Some guys prefer the H while others swear by the X. Me, I just like the way the X pipe is set up and the fact that Ford is now using it for the V6.
As far as warranty issues, there shouldn't be a problem unless Ford can prove your exhaust pipes did something with the engine. I've never readany complaints so far.Being that my car is an '07, that was something that crossed my mind many times. I even called the dealer asking them if they could install duals but at the time they didn't have the parts nor the info. They recommended meto take my car to a local shop that they use for V6 conversions.
When I stopped by a local Ford dealer to pick up a brochure, one of the salesmen asked where I had the work done, that it looked like a factory job.
Average price to install duals if you supply the parts, between $80-200.
#23
ORIGINAL: GrayPony
What are true duals without mid pipe?
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
