Clamps
Clamps
I posted yesterday about my mid pipe slipping out. I took it to the shop this morning and they said the bolts were on tight, so they put a couple of tack welds on to secure it. They pointed out how cheaply made the clamp is from Pypes compared to the OEM part that was on the old exhaust. You could see how thin Pypes clamp is.
Anyone got the part number for a clamp?
Anyway, here's a picture of the Pypes clampand the Ford Clamp;
RE: Clamps
I had the part number from Ford. They are about $30 bucks per clamp. I was going to order all Ford parts from the parts department for my exhaust, but it ended up being like $50 bucks more. Since you are having problems with the pypes clamp, I may just end up doing the all ford parts stuff.
RE: Clamps
The only bad thing about the situation now is the tacks on the pypes clamp. IMO that style clamp is fine, I use that style in some extreme duty situations and theyhold up fine, and now that they are tacked you shouldnt have any problems at all. BUT if you try to remove the old clamps to replace with OEM there is a very good chance the mechanic could burn a hole in your pipe removing the tacked on pypes clamps. Looks to me you shouldnt have any worries with your setup now though!
RE: Clamps
I think the whole idea of a tack weld is to loosen it by knocking on it a little. Now if they had welded all the way around, yeah, that could burn a hole in the pipe.
The owner of the shop told me the clamp is not a good quality one and in time could break. I could see the difference in thickness in the two and must say Ford makes a better clamp. Not only that, but the way the pipes slip in that clamp doesn't seem as secure like they are on the OEM part.
RE: Clamps
ORIGINAL: ODDYSEY
Pypes do make good quality X-pipes and mid pipes.....it's just the clamp that I am having issues with.
RE: Clamps
Im sorry but the amount of weld they put on there will take more than just a hammer to get the clamp off. If he knows what he is doing they will take a die grinder to get the clamps off but just a hammer wont do it in this case.
RE: Clamps
ORIGINAL: Wickerbill
They build race cars from the bottom up.
RE: Clamps
ORIGINAL: 07 Stang
I contacted Ford Direct Parts and got a part number as well as price;
The part number is 4R3Z-5A231-AA and cost is 20.29 plus 10.95 shipping.
