? about lowering springs
I want to lower my car. is just getting lowering springs worth it with the stock everything else? ( as u can tell i dont a whole lot about suspension) Should i wait and do springs and more? thanks for your help guys
RE: ? about lowering springs
What size tires do you have on your car? I added the 17" take-off rims and tire from a GT. I then put the Eibach Pro-kit lowering springs and they made a huge difference in both handling and looks. The Pro-kit lowers the wheel around 1.2-1.5" which doesn't sound like much but you'll be surprised at how many times your undercarriage will bottom out on bumps and driveway entrances if you're not careful. If you go with the springs you might want to add either a GT rear sway bar take-off or a matched front and rear from Eibach like I did. You can do the sway bars yourself if you have basic mechanical skills but leave the springs to a pro
yeah springs areworth it. idk about with stock wheels as far as looks. i did my lowering when i put my aftermarket wheels on. but they do improve performance. i got the sportline which drops your car 1.75-2.00". alot of bottoming out will happen if youre not careful. but its worth it. looks amazing.
depending on how low you go you will need more. i did the steeda springs that lowered the car 1in. not much but around my town any lower really sucks. i did the springs and panhard bar at work on a saturday, took two of us a hour and a half. we had a lift and spring compessor. i also did an alinement wile i was at it. i was able to put the camber in specs without a camber kit and the panhard bar needed to be ajusted because the thrust angle of the rear axle was off to the left. if you go lower than 1in, you will need a camber kit.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
