CATS or NO CATS?
RE: CATS or NO CATS?
ORIGINAL: ilmor
Thanks...and I prefer the clean, no rear spoiler look...and at some point I would like to hear the V6 growl. I like all engine sounds!!
Best sounding sixer I've EVER heard.
ORIGINAL: Jsierzega
taking the cats off of your v6 will reduce back pressure killing your low end torque and hp
ORIGINAL: Sancho805
negative....it will free the flow which will slow down velocity of the gases and thats what lowers your torq a tad, not hp. backpressure is bad.
ORIGINAL: Jsierzega
I currently have MAC Long Tube Headers, MAC Off Road H-Pipe, No CATS and SLP Loudmouths. While it sounds AMAZING at idle, it's too much for me to handle while driving since the whole car shakes. I'm keeping the setup and just putting back on the GT Takeoff mufflers to HOPEFULLY reduce the noise/shaking.
ummm.....negative wickerbill. backpressure is "BACK" pressure. putting pressure back into your pistons does NOT help your car, makes it work harder which lowers performance. the vacuum you mention brings it back to the engine. how can that be good? zero backpressure is not likely but the least amount possible is the goal and the same time, maintaing high velocity of exiting gases. the faster those gases get out, the faster and easier your engine can work. explain how your vacuum theory pushes out becuase i'm not understanding your definition. the vacuum is actually bringing gases back in which is definately not ideal.
Wickerbill,.....OK, thats how i understand the "vacuum" effect happens also but how is that backpressure? that "vacuum" comes from high pressure entering a lower pressure area. if the pressure in the exhaust port is greater than the pressure in the cylinder, the "vacuum" effect would bring exhaust gases back into the cylinder which contaminates the air/fuel mixture, right? the only way i can understand how a minimal amount of backpressure is beneficial would be if the intake/exhaust valve overlap is long and air/fuel has the chance to enter straight into the exhaust port. the backpressure would block that clean mixture and keep it in the cylinder but also "leak" some exhaust back into the cyclinder causing contamination. seems to me that valve timing is critical so that backpressure is not used to keep air/fuel in. I KNOW that an engine isnt perfect but i can't understand how backpressure is a good thing. backpressure "pushes" gases back in, not vacuum out. basic physics can explain that. i'm sure your engine work experience puts you higher than many of us in the auto world but physics is physics and it doesnt take an engine man like yourself to figure it out.
http://www.superchevy.com/technical/...t/0505phr_exh/
Scroll down to "Headers -- Primary Pipe Diameters"
"Big pipes flow more, so is bigger better? Answer: absolutely not." Same goes for the cats/no cats argument I would think - there is an optimal level of exhaust flow...too much flow = no scavenging, too little = too much back pressure and decreased performance. Taking the cats off would be too much flow for a non - f/i V6, at least that's how I see it.
