Areas to snag power other than lighting?
Old 10-15-2007, 11:54 AM
Caladius
Caladius's Avatar
Default Areas to snag power other than lighting?
unfortunately i realized that splicing the constant from the parking lights meant a slight loss in power to the driver side lights. Is there anywhere else i can run an external power line to another constant? (i.e the horn, fuse box, battery.)
thank in advance
Caladius is offline
Old 10-15-2007, 12:41 PM
banka87
banka87's Avatar
Default RE: Areas to snag power other than lighting?
I'd go after the horn, personally.
What are you trying to do anyway?
banka87 is offline
Old 10-15-2007, 12:51 PM
Caladius
Caladius's Avatar
I recently installed a set of Fog lights for my v6 mustang. i had spliced the parking lamp constant on the drivers side and that in turn dimmed the driver side lights. my dad says that wont matter for inspection purposes but itd be annoying for me to subconsciously know that my lights are retarded
Caladius is offline
Old 10-15-2007, 12:52 PM
banka87
banka87's Avatar
The instructions didn't give you something to splice into?
banka87 is offline
Old 10-15-2007, 12:59 PM
Caladius
Caladius's Avatar
yea the instructions said to splice the parking lamps, which we did. everything works just the driver side is dimmer than the passenger side, id like to avoid splicing the parking lamps to solve that problem..
Caladius is offline
Old 10-15-2007, 01:06 PM
GrayPony
GrayPony's Avatar
Did you use a relay or go direct? You should only be using the parking lamp signal to close a relay... NOT power the lights.
GrayPony is offline
Old 10-15-2007, 01:12 PM
Caladius
Caladius's Avatar
+1 which is what i did the first time and need to go back and fix.
Caladius is offline
Old 10-15-2007, 08:01 PM
emconn
emconn's Avatar
Yeah I went ran mine to the marker lights and I had to run a relay. Tried without and it wont work. Doesnt dim the headlights or anything.
emconn is offline
Nick Oliver
10-17-2018 04:22 AM
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
zachary1988
09-04-2015 03:04 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Areas to snag power other than lighting?
