new tires help plz
RE: new tires help plz
ORIGINAL: Dennis074.0
get bigger wheels, and tires.
dont waste the money to put the 16"ers on.
MADMAX
Before you buy those tires ! If you decide to go with 16s the 225/55/16 is not the recommended replacement size .
These tires are a bit shorter ,and will change your speedo calibration somewhat and would NOT be in the proper load range and service description. The most direct sizes if you stick with 16s are 235/60 16 and 255/55/16 .
I have 255/65r16 Grabber UHP's on the back of my car on the stock 16's.
I think they cost me $105 each mounted and balanced locally.
Try to find a pair of wide 17" tires for that cheap.
They run really nice.
Plenty of traction and fill out the rear wheel wells nicely without dealing with lowering it at all.
The ride is rough enough, lowering it would have made it unbareable.
I have a set of 17" bullits waiting for tires, but I couldnt justify $120 each for the stock size up front and $144 each for fat tires out back.
I only really needed new rear tires, so it was WAY cheaper.
When these tires get destroyed or wear out, I'll replace them with the 17's.
