Painting Calipers?.....
Old 11-06-2007, 04:44 PM
Sancho805
Sancho805's Avatar
Default RE: Painting Calipers?.....
awesome...thanks for the tips fellas. and the white does look pretty damn cool too rmays06 but i bet it gets covered up in dirty grease quickly. or does it not?
Sancho805 is offline
Old 11-06-2007, 04:57 PM
nonstopred
nonstopred's Avatar
I got the duplicolor kit in red. It brushes on. Took me about 4 hours. The main thing that I spent time on was masking, because I wanted it to come out perfect, and not have any stray paint anywhere that it shouldnt be. Then I had to clean, and then I did 2-3 coats. let dry over night. Still holding up pretty well
also, get the stickers from www.xenonmods.com
nonstopred is offline
Old 11-06-2007, 05:21 PM
Razorbackfan
Razorbackfan's Avatar
Painted mine over the weekend using the GS2 paint (got it on ebay). It's VERY easy. Brush it on, let it sit, brush on another coat, let it sit overnight. The paint when dry has a rubber like feel to it. Temp rated to 950 degrees. I like the way it looks.
Razorbackfan is offline
Old 11-06-2007, 06:31 PM
Rdot9
DubStep Stu
Rdot9's Avatar
It was real easy to do, i used the duplicolor paint...
Rdot9 is offline
Old 11-06-2007, 10:34 PM
rmays06
rmays06's Avatar
To be honest it didn't get to bad at all. I wish I had a good pic for you mainly it look like an off white unless I just washed it. I like the attention it got so in the long run it was worth it.
ORIGINAL: Sancho805
rmays06 is offline
Old 11-07-2007, 08:15 AM
TPony
TPony's Avatar
Ensure you have everything you need and time, to do all 4. So that once you start, you can finish. Also, recommend not drive the stang within 24 hrs from painting it...
TPony is offline
Old 11-07-2007, 01:08 PM
luvrbcs
luvrbcs's Avatar
ORIGINAL: nonstopred
+1 on the stickers.
[IMG]local://upfiles/2752/2AB7096C4A9A47FBA0D2AEBF2AEDC79A.jpg[/IMG]
luvrbcs is offline
Old 11-07-2007, 01:42 PM
MrSandman
MrSandman's Avatar
Not that bad from my experience. I just wipe them when I wash my car...
ORIGINAL: Sancho805
MrSandman is offline
Old 11-07-2007, 05:08 PM
TheBlackPearl
TheBlackPearl's Avatar
mine actually started chipping... I have to do mine over again
TheBlackPearl is offline
Old 11-07-2007, 05:18 PM
pascal
S197 Section Modder-ator
pascal's Avatar
Here's mine with Acrylic Enamel.
Dupont Centari, to be exact. Single stage stuff (with activator of course).
I've been doing calipers for years this way and it's a good old trick that works. Good Enamels can withstand a lot of heat.
I don't disconnect any lines, just mask real good (I cover the whole car to prevent overspray)and shoot atlow pressure.
[IMG]local://upfiles/78700/CD93494416F546CAAE5DF00358562771.jpg[/IMG]
pascal is offline
Quick Reply: Painting Calipers?.....
