Whats the best idle rpm?
RE: Whats the best idle rpm?
+ 900. I can roll forward from a complete stop letting out on the clutch without touching the gas. Great for stop & go traffic and the Dunkin Donuts drive-through.
Ok cause it seems like it is just using alot of gas and ime trying to save but i have it set at 900 now, and sancho yes you can tune that with the diablo.
ORIGINAL: samv1368
ORIGINAL: besam
how do you do that on the SCT Xcall2, i just tried and couldnt figure it out lol
From there you scroll down until you get to idle rpm and select it and change it to your liking.
Now keep in mind guys you have options here if you have a stick.... for an auto, most people dont put it in neutral or in park at a light, but you can change NEUTRAL idle rpm and your idle in gear. Only change it in gear and you will waste next to no gas, at least if you drive like me...at stop signs and short lights when you don't actually put the car into neutral, just have the clutch in it will stay at the in gear idle. At long lights and what not, where you actually put the stick into neutral, it will go to the stock idle rpm....no gas wasted.
Originally I think mine was set at 800 RPMs and no there is no problem with running it that way and at 100 RPMs more or so it wont guzzle gas either. You are that much closer to your powerband IMO. later J
ORIGINAL: pat6674u
I have mine set at the same RPM. Is there any potential problem (other than guzzling gas) to having the rpm so high. I think stock its like 700.
ORIGINAL: mygt500
I have a tune and on the SCT it is set at 900 RPMs
I think with the SCT xcal2 you can set the idle RPM's at 1500, probably waste alot of gas this away, LOL.
Not to hijack, but on my SCT tuner, I dont remember there being a place where I pick "load a tune". See this is my problem, I'm not sure if I ever got the tune loaded into the car. All I did was plug it in, change the octane to 93 and thats it. I'm so pissed, my car probably isnt even running to full potential because I'm so dumb and cant figure out the SCT tuner. [:@]
ORIGINAL: Sancho805
hmmm....i was just thinking......maybe at the higher idle, the dash rattle may go away or decrease [>:]. dead stops is when i get the wicked rattle, so maybe at 900rpm the wickedness will end? ima try it out and see what happens. i'll let u all know the results.
ORIGINAL: samv1368
with an auto, wouldnt upping the idle RPM make it harder to stop? i know those of us with sticks its not a problem but i figure its something to look out for if you drive an auto..
