pp faster than a non pp?
RE: pp faster than a non pp?
ORIGINAL: ArcticFrog
Ford states the 17" Pirelli tires/bullit wheels are the largest wheel they've ever put on a V6 pony.
No, the V6 is faster that the PP as it weighs less.
The difference between 16" stockers w/BFGoodrich tires
and the 17" OEM w/Pirellis is traction and not outer diameter.
They are the same outer diameter so the speedo reads right with
either the 16" or 17" rims with OEM tires.
ORIGINAL: 157db
ORIGINAL: 07 Stang
Right, and they say the Pirellis have better traction therefore making the PP a wee bit faster. According to some car sights, it was clocked about 3 seconds faster.
ORIGINAL: 157db
ORIGINAL: Legion5
Don't you mean .3? P zeros are just aweome no mater how you slice them.
ORIGINAL: 07 Stang
ORIGINAL: 157db
ORIGINAL: 157db
seems like if you answer the thread question literally, the answer could be yes, even though it may be a very small amount. if you rephrase the question with "does the pp have more POWER than a non pp" than the answer is obviously NO. better street handling from the PP should be at least some advantage over the standard 4.0 which would translate into a quicker time.
as for the 17" pirellis outside diameter being larger than the stock 16" skinnies, i dont know. when i switched my skinnies with my new GT bullits, i placed them side by side and they appeared the exact same height. if the 17's are larger, than the difference must be just a few millimeters and that cant be considered a difference when dealing with tires IMO.
