Check engine and electronic throttle system light on
I have a 2005Mustang nothing done to it yet just bought it but after a month the check engine light has come on along with the electronic throttle light what does it mean? I also want to know how to install an amp wiring kit in the stock 500 shakker system or if i should put in a new hu?
RE: Check engine and electronic throttle system light on
check the following TSB:
http://bradbarnett.net/mustangs/gala...4_04wrench.pdf
this is for early 2005's... built before December 2004.
Ok thanks for the help I just ran my scan tool on it and it came up with these codes:Stored P2104 Throttle Actuator Control System-Forced Idle, P2106 Forced Limited Power, P2135 Throttle/Pedal Posistion Sensor/Switch A/B Voltage Correlation and Pending P2104, P2106, P2107, P2110, P2111, P2135. Any help thanks.
ORIGINAL: up_yours_7
My car started doing the same thing... got worse over the course of a couple weeks... I just bought a new throttle body which includes an new sensor... it was pretty reasonalby priced..
No its not under warranty where would a good throttle body be located for purchase? What would be the first thing I would want to do to start mods with not much money??
Anyone have a picuture of where this sensor is located under the hood? I ran into the same issue once, but have not seen it happen again. But just in case I need to replace it, I know where it is.
How hard of a install would this be?
actually... looking at the TSB... looking at the wording:
WARRANTY STATUS:
Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage And
Emissions Warranty
Coverage
Might want to go talk to your friendly Ford service manager... I think the Emissions Warranty is longer that the 3/36... See what they can do for you...
