Should I have to Pay????
RE: Should I have to Pay????
ORIGINAL: dmc2904
lol the who???? the whats???
Seriously though, what do you mean?
ORIGINAL: 157db
Did they check for a wet passengers side
carpet? Yous gots thes dreadeds waters leaks?
What year is your Mustang? Have you checked the flooring on the passengers side near the smart box for moisture? Those that have had problems, experienced the carpet in that area kind of wet.
So far I've had mine a year with no problems, but I do not drive it in the rain.
ORIGINAL: 07 Stang
It is possible that your car has a dreaded leak that has plagued many Mustang owners. If you do a search on Leak here on this forum it should bring up a lot of topics on the subject.
ORIGINAL: dmc2904
ORIGINAL: 157db
Sounds like the dreaded passenger side waterfall to me... Ford FINALLY put out a TSB on this issue (about a year too late for me...I had to diagnose and fix mine myself after the dealer tried 8 times and didn't fix it): http://home.nc.rr.com/mackowsky/car/tsb07-14-06.pdf
ORIGINAL: Torch_Vert
Being a manager at a dealership I can tell you that if you have been in for diags that may have been caused by a mod (amps) and no codes show up they will be quick to charge you a service charge. Just explain that you did a proper install and not some hack job. Failing that go to another store that does not know your history.
