V6: Stronger Internals than V8?
Old 12-31-2007, 09:37 PM
  #21
LX200
LX200's Avatar
Default RE: V6: Stronger Internals than V8?
The stock V6 handles better than a GT when it has the GT sways on it. No way the stock V6 handles better than the GT.
LX200 is offline
Old 01-01-2008, 04:03 PM
  #22
Margarita Girl
Is the tide gonna reach my chair?
Margarita Girl's Avatar
ORIGINAL: oshkoshbajawsh
sounds like margarita girl has had one too many margaritas. light weight change your name
Now you've gone too far.
Transmission:
V6 = T-50D
V8 = TR 3650
Gear Ratio:
V6 = 3:31:1
V8 = 3:55:1
Suspension:
V6 = 28.6mm tubular stabilizer bar (front)
no rear stabilizer bar
V8 = 34.omm tubular stabilizer bar (front)
add 22mm solid stabilizer bar (rear)
I can give you the difference in the bore x stroke, displacemnt and compression ration too if you need it.
Margarita Girl is offline
Old 01-01-2008, 05:18 PM
  #23
pascal
S197 Section Modder-ator
pascal's Avatar
No need to work that hard girl...
You showed him.
pascal is offline
Old 01-02-2008, 08:56 AM
  #24
07 Stang
07 Stang's Avatar
ORIGINAL: Margarita Girl
Suspension:
Again, on the Pony Package there is a stabilizer bar.
Did you test drive a Pony Package or a Base V6 model? They are different when it comes to handling.
EDIT: I fixed your quote - 28HopUp
07 Stang is offline
Old 01-02-2008, 09:04 AM
  #25
28HopUp
MF Administrator
28HopUp's Avatar
ORIGINAL: 07 Stang
Margarita Girl said on page 1 that she test drove the two cars in 2005, and the Pony Package wasn't available back then. So she drove a 4.0L V6 with the regular suspension and 16" tires.
28HopUp is offline
Old 01-02-2008, 09:22 AM
  #26
07 Stang
07 Stang's Avatar
ORIGINAL: 28HopUp
ORIGINAL: 07 Stang
Aaaaaaah! See, that's like driving a rental Mustang and trying to compare it to the rest of the line up.....it just doesn't match.
Not saying there is anything wrong with the base model as there are many 4.0 members here who arevery satisfied, but you can't compare apples to oranges.
07 Stang is offline
Old 01-02-2008, 10:53 AM
  #27
Sancho805
Sancho805's Avatar
do sway bars make that much difference? or is it only mostly felt when cornering at higher speeds?
Sancho805 is offline
Old 01-02-2008, 11:28 AM
  #28
07 Stang
07 Stang's Avatar
ORIGINAL: Sancho805
From what I understand, it helps mostly with high speed cornering, but who knows. I've heard others say it does make a difference in the way the car handles.
07 Stang is offline
Old 01-02-2008, 04:45 PM
  #29
pascal
pascal's Avatar
Makes a difference at any speed...
It's for hard cornering, witch can occur at 25mph or lower.
In other words, it helps prevent body roll.
pascal is offline
Old 01-02-2008, 04:57 PM
  #30
Sancho805
Sancho805's Avatar
ORIGINAL: pascal
so how much for a rear sway bar? [8D]
Quick Reply: V6: Stronger Internals than V8?
