RE: Buying Duel exhaust soon. What are some good pipes?
ORIGINAL: OIIIIO
ORIGINAL: 07Mustang_On_18s
what are the benifits of H and X pipes?
H pipe = more power (mainly torqe) low in the rpm range.
= deeper tone.
X pipe = more power (hp) higher up in the rpm range.
= higher pitched tone.... nore raspy.
That is only on a GT, ont he V6's there is next to no difference in H/X on a V6. There is a slight change in exhaust tone between the two, and Ford uses an X on their own V6 exhaust kit.
A little more sound but it will never sound like a V8. if you are looking just for power benefits, I believe if you search through these forums you will find that going with headers, x pipe, off road pipe (no cats) vs just an axle back might give you 2 maybe 3whp more at most but you spend time and $$$$. There just isn't any benefit unless you are going supercharger.
if you just want the look of duals,then look up the Pypes tru duals as they seem to be priced well
