oh btw I loaded justins tune.
I got the 91 oct performance tune from him. So in the meantime I finally got an oppurtunity to test this beast out. And I first tried to do a burnout.. and I have to say I just floored it in my auto and the tires lit up for 3-4 secs and the I let off. So this is something I couldnt do on my canned tune. so thats an improvement. I also notice the car feels stronger under normal acceloration and WOT. Shifts are much firmer also. Great tune 9/10.
RE: oh btw I loaded justins tune.
ORIGINAL: ManOfMustang
Mustang_Guy 17..im just curious..do you have pictures of your system and how you hooked it up..thatd be tight cause im thinkin about gettin some subs myself..does your trunk rattle bad in any spots?
our trunks rattle hard. buy some dynamat. you'll appreciate it alot when you hear the difference. trunk rattle sucks, i solved mine by mounting my single sub (soon to be 3 subs) where the back seat used to be. no trunk rattle and looks so sick when firing.
i went from box in tunk w/ no dynamat, to getting dynamat (there was some difference) but it was totally different once i put it where the seat back should be. the project's still not done. i still have to add two more 10's and one more amp. anyways... the sound is still excellent and there is NO TRUNK RATTLE!!! that was the best part. i did the mounting as an aesthetic mod, and it ended up fixing my annoying rattle. this look isnt for everyone though. so yeah. i like show alot, so it was right for me. the install is kinda tricky though as the area for mounting more readily accepts 10's but a 12 will fit. good luck with your system install. i reccommend a pro install it unless youve done it before.
oh and if you decide to mount the subs like i did mine, make sure you use sealed (and i meanCOMPLETELY SEALED)boxes. you cant port inside the cabin or have any air escaping. sounds like ****. i found that out the hard way.
