Problems about the CAI from ebay
I bought a CAI from ebay(http://cgi.ebay.com/ebaymotors/COLD-...em150223398665), but it didn't have any direction.
so, i got some problems to install it.
Does anyone buy the same CAI?
I need some picture to show me how to install it.
RE: Problems about the CAI from ebay
You are probably having problems because it was made poorly and doesnt fit. CAI installs are really straight forward, check out the websites of other CAI manufacturers for instructions on their systems, they are all about the same.
Well... it looks fairly straightforward. The blue part connects to the throttlebody.. the support part of that tube probably rests on the inner fender area, and then two parts from your stock intake tube--the MAF sensor, and the oil return plug--go into the spaces that are provided on the new tube.
it is straight forward. hardest part, if you can call it hard, would be installing the heat shield. after you match the holes with the fender and screw it down, the intake tube braket that is welded on bolts onto the heat shield and of course, the silicone coupling attached to the throttle body.
