Ford sucks!
RE: Ford sucks!
my car is an 06 with 25000 miles on it... And I have the dual magma flows with the hangers that came with it. I contacted magnaflow and they told me that it was because I lowered the car.
RE: Ford sucks!
ORIGINAL: laserred02
If Ford built the car correctly in the first place it wouldn't be leaking oil. I don't know how old his car is or how many miles, but it is pretty early for these cars to be leaking oil. Especially enough that a pan gasket would need to be changed.
ORIGINAL: SteelStang05
Yeah. Oil leaks happen on ALL cars. You just found a dealership with lazy mechanics and/or special ones. Best bet is to find another and not blame ford for it. You did buy their car correct?
ORIGINAL: Sancho805
try another dealership.
RE: Ford sucks!
well im at the dealership right now and the service guy told me that it usually doesnt happen this early with the amount of mileage on my car... but anyone have a solution for my exhaust? could i put some type of padding on the rear sway bar so i won't hear this clunking all the time?
RE: Ford sucks!
Is that comment serious? My dad's old car a BMW with low miles (under 35k) had an oil leak, and aren't they supposed to be one of the best engineered cars on the market? And my friends dad's infinity had an oil leak with less than15k on the clock.**** happens after cars leave the factory. Whether a leak was caused by a little beating on the car, an assembly line malfunction, or something else, they happen on all cars no matter what the mileage. This is why almost any newcar comes with a warranty from the factory.I'd hate to see you with an expensive car, you'd probably be complaining aboutevery little thing that doesn't sound or look right
ORIGINAL: Sancho805
RE: Ford sucks!
Yes it is serious, the car shouldn't leak oil this early, and that is the bottom line. Don't insult me for wanting my car to be right, and sympathizing with another person who feels the same way. Also in my opinion this in one expensive *** car, and maybe you would know that if you made the payments on your car rather than your parents. Look kid, once you grow up and have some experience you can comment on these things, but while your parents are still fitting the bill it is best to keep your uninformed opinion to yourself. Some of us would like our cars to last for a long time because they are expensive and oil leaks early on are a poor indication of longevity.
RE: Ford sucks!
Now now.. we all know what e-argueing accomplishes.
I don't care if I had a $100 car or $100,000 car. If it is under warranty, I would want it fixed. And if it was low mileage, I would expect it to not leak oil. Technically speaking, any car leaking oil is broken, because they are designed and built to NOT leak anything.
Just because they do, does not mean they are right, or mean you should let it slide. Just my opinion, but don't get your panties all in a bunch.
RE: Ford sucks!
I didn't know I was arguing with your dad, LOL?? Yes I rebuilt the straight six in my 1966 mustang, so I have taken apart and put motors back together. Oil leaks are not normal, and they can be indicative of future problems, just because they don't always cause problems doesn't mean they should not be addressed.
Maybe you should spend more time deciding which completely new direction you are going to take your car this week, and less time responding with what your daddy told you about some guy one time.
RE: Ford sucks!
first off i would find a nother delaership to do your work if your not happy with the one you are using, or find a recommended and relaible custom shop to do the work.....as for the flows banging the bottom of the car ...i am not lowerd and have never had this problem so it sounds like theinstall could be suspect....as for the oil leak....well they happen all the time unfortunatley...but if i may suggest.....check the oil pan where the bolt goes in to drain the oil....i had a constant leak that no one could figure out till i got the oil changed (this was on a different car mind you) but it seems the previous two guys missed putting a small washer back on between the bolt and the pan....the washer was like 10 bucks...i had it replaced (well it was lost i guess by jiffy lube or some place like that (one reason i never go to those places unless desperate)) the guy put the washer on..problem solved..again this is only one of many possiblites as why your leaking....hope this helps
on the whole tho...find another dealer sonds like the one your going to is up to snuff..
RE: Ford sucks!
RE: Ford sucks!
well the cars at the dealership. and its gunna be there for another day or two. i took the exhaust to 2 places and its only the right exhaust pipe that bangs. i was actually under the car with them tryna figure out how to fix it... but the most clearance we could get was about a quarter of an inch... the exhaust is really starting to bother me... HELP ME!!
