C&L Install
C&L Install
Hey,
Well, I've been comtiplating rather to go ahead and get the intake and tune or not... Before I do though, I was wondering how easy the install is with a C&L intake, considering I will probably be going with VMP Tunes. Comments would be greatly appriciated. Also, if you have any guides, that would be great too so I can look over it myself.
Thanks!
Thanks!
RE: C&L Install
i'm a total dumb *** and i did it. it's pretty simple actually, make sure you have an 8mm and 10mm (i think) socket. the 8mm is used to take off the elbow inlet housing from the throttle body. on the stock airbox there's only one screw. then use the 10mm socket to loosen the screw that keeps the airbox attached to the body of the car on the drivers side to the front. disconnect the MAF sensor thing and some weird tube thing that i have no idea what its called. pull out the air box and then use a special little driver head (i don't know what it's called, when i got my C&L from brenspeed it came with it, but they give you 2 regular phillips head screws to put the MAF thingie back in) to take out the MAF thingie in the airbox. putting together the C&L CAI took me more time then removing and installing.
after you get the CAI installed, put the MAF thingie in the appropriate slow and be sure the air flow symbol points to the throttle body. attach the elbow to the throttle body, tighten it up slightly using the 8mm and then secure the heatshield to the body with the 10mm and after making sure everything is properly adjusted, tighten the throttle body screws, and connect the MAF sensor and the tube thingie then load your tune.
just to prove how much of a dumbass i am, go back and count how many times i used the word thing and thingie. if my dumbass can put a CAI and load a tune, so can anyone. after a while you really pick up on how easy and quick ways to install. when i put mine in originally, instead of putting the CAI together first, i did it piece by piece then i realized "wow, i'm stupid". just using my mistakes to make it easier for you
RE: C&L Install
ORIGINAL: ScreamingYellow2005
iT'S SO EASY A CAVE MAN CAN DO IT
RE: C&L Install
The toughest part for me was getting the hose off the throttle body (I did it with a broken wrist) and figuring out how the Mass Air Flow clip detatched. Easy install.....don't be skeered. Xcal tuners go step by step on your tuning.
You will be glad you did it.
