GT Gauges???
#61
RE: GT Gauges???
Challenging withthe idiot lights?
Couple questions...for me.
1) When you say the milage did not transfer...do you mean that the milage displayed is what your car has on it or what the new clustercame with?
2) You mention the speedo is correct? How have you compared it to ensure it is not the 16% off?
Couple questions to help you.[sm=nerd.gif]
Could you kill the ABS and TCS lights? (pull or break bulbs?)
Do you have a scan tool? Does it through any MIL codes?
The E-break is the hard one. Again this is CAN bus. The E-break goes to the SMJB who translates this to the cluster. So you may need someting to be flashed to work 100% with the components.
#62
RE: GT Gauges???
the milage on it displays what the cluster had when it came.. its 40K less than whats on the car... I havent checked to see if the speedo is 16% off, but it seems right.. ill run that test tomorrow... havent run the scan.. going to advance tomorrow to scan it and try and fix the codes.. hopefully that will kill the lights... ill keep everyone posted
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
